Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Spiral Stair
5 REPLIES 5
GHASEM_ARIYANI
419 Views, 5 Replies
Spiral Stair
Hello
how to add a connection in the AS Spiral Stair?
like, the attached image
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
5 REPLIES 5
maybe you clarify what you want to do?
the stair tread is bolted so, what do you want to change?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
the attached image is straight.
 I want this connection used in the spiral stairs.
Does anyone have a suggestion?
Hi @GHASEM_ARIYANI
In the spiral stair macro you have these options in the "Tread connection" tab then you have a sub tab "Treads - outer stringer" see screenshot below
Rob Merriman, AEC Technical Lead, Graitec
thanks for the info
