Hello
how to add a connection in the AS Spiral Stair?
like, the attached image
maybe you clarify what you want to do?
the stair tread is bolted so, what do you want to change?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
the attached image is straight.
I want this connection used in the spiral stairs.
Does anyone have a suggestion?
In the spiral stair macro you have these options in the "Tread connection" tab then you have a sub tab "Treads - outer stringer" see screenshot below
Rob Merriman, AEC Technical Lead, Graitec
