Special Parts and Symbols Library in Advance Steel
acbsdesign
Mentor Mentor
Message 1 of 20
acbsdesign
Just spent a decent amount of time converting manufacturer's dwg files to special parts so they can be inserted in the model.
Special parts such as base flanges for railings posts, wall brackets for handrails, Speedrail (R) parts, special bolts, nuts and washers, flanges for pipes, U-Bolts, anything that may come across-please share it here.
The attached file is in Imperial units,
Wagner Base Heavy Duty Flange Part 1623HD for 1-1/2" (1.9"OD) pipe, welded type
For those willing to share-Please make the text bold and underline when listing.
Thank you in advance and have a great day.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Replies (19)
Message 2 of 20
markhubrich
Message 3 of 20
acbsdesign
Nice work @markhubrich
Keep them coming.
Thank you for sharing.
Message 4 of 20
acbsdesign
Splice-Lock for 1.5"STD (SCH40) PIPE
Custom connection right and left, it will create hole in pipe and add the splice-lock.
Splice-lock-3318
Dwg attached.
Regards.
Message 5 of 20
acbsdesign
Wagner Base flange Welded Type no holes for 1.5" (1.9"OD) Pipe
Wagner Base Flange for 1.5" Pipe Part 1434
Message 6 of 20
acbsdesign
Wagner Base flange Welded Type no holes for 1.5" (1.9"OD) Pipe-Please use this dwg
Message 7 of 20
acbsdesign
Splice-lock-3318
Dwg attached.
Regards.
User section for 3318 attached for use with the custom connection.
Message 8 of 20
Adrian.Mangan
Have you tried fusion are any similar elements available in https://www.mcmaster.com/.
These are available to insert into fusuion and could be exported and then imported as special parts.
Message 9 of 20
acbsdesign
Yes, I take parts from McMaster very often.
Manufacturers (most of them) did not bother creating 3D model of the parts.
Message 10 of 20
lowell.mcclain
Wagner #3418 2 1/2" CL Wall Bracket
May need a couple of little "fine-tuning" tweaks, but is modeled to the Wagner dimensions. It is also the same as the 1251R bracket, except the 1251R has two holes for screw attachment to the pipe. So a simple copy and rename will give you the 1251R bracket as well.
Message 11 of 20
acbsdesign
Re: WAG 3418:
Attached is the bracket positioned per UCS.
Message 12 of 20
acbsdesign
I found a good site for 3D models of special parts:
https://info.traceparts.com/use-and-manage-3d-cad-models
Message 13 of 20
Adrian.Mangan
Hi
Here's one I create in fusion couple years ago, a grating clips, someone just asked me for it so maybe its helpful to someone.
Both files are same item just different versions of Autocad (as 2013 was requested.)
Message 14 of 20
Hi Ilko,
Autodesk has no user portal for file sharing? 🤔
Message 15 of 20
acbsdesign
@Anonymous wrote:
Hi Ilko,
No sir, not aware of any.
This is why I decided to start this thread here, after spending 10-15 minutes on a more complicated special part, it is a non-sense to keep such things for one user only, it is a much better way if can be shared between users.
Have a great weekend. It is getting really hot here around Boston.
Message 16 of 20
acbsdesign
WAGNER Round base for 1.6OD Pipe (Similar to WAG 1427A but without holes)
Message 17 of 20
CHIP888
Wagner-1612
Message 18 of 20
CHIP888
Was able to download direct from Mcmaster
xxx.step files, explode to 3d solid, and save the special part.
I wish wagner had 3d files of their rail components.  cp
Message 19 of 20
acbsdesign
@CHIP888
Nice work.
Message 20 of 20
acbsdesign
WAGNER 4386 RING, Steel, mill finish, 4" OD, 1/2x1/2
