1- What is this structure underneath called?
2- How do I draw it (I tried drawing it with T steel and then cutting the sides? Is there help or outside sources that don't make it structural?)
1-ماذا يسمى هذا الذي يكون في اساس العمود
2-كيف يمكنني رسمه (لقد حاولت رسمه ب steel T ثم قمت بتقطيع الجوانب ؟ هل من مساعدة او وصادر خارجية لاتغلم structural )
1- Comment s’appelle cette structure en dessous ?
2- Comment le dessiner (j'ai essayé de le dessiner avec de l'acier en T puis de couper les côtés ? Y a-t-il de l'aide ou des sources extérieures qui ne le rendent pas structurel ?)
Solved by Sebastian_Eiche. Go to Solution.
maybe something like that:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
Thank you it did what I wanted, can you tell me how to find this palete( AS versions student)
in the connection vault:
Sebastian Eiche
Sebastian Eiche
