Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Special building/structure
3 REPLIES 3
o.benafghoul
312 Views, 3 Replies
o.benafghoul
1- What is this structure underneath called?
2- How do I draw it (I tried drawing it with T steel and then cutting the sides? Is there help or outside sources that don't make it structural?)
1-ماذا يسمى هذا الذي يكون في اساس العمود
2-كيف يمكنني رسمه (لقد حاولت رسمه ب steel T ثم قمت بتقطيع الجوانب ؟ هل من مساعدة او وصادر خارجية لاتغلم structural )
1- Comment s’appelle cette structure en dessous ?
2- Comment le dessiner (j'ai essayé de le dessiner avec de l'acier en T puis de couper les côtés ? Y a-t-il de l'aide ou des sources extérieures qui ne le rendent pas structurel ?)
Tags (1)
3 REPLIES 3
Sebastian_Eiche
maybe something like that:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
o.benafghoul
Thank you it did what I wanted, can you tell me how to find this palete( AS versions student)
Sebastian_Eiche
in the connection vault:
Sebastian Eiche
Sebastian Eiche
