Hi, I have a problem with decreasing space between dimensions chains. I've tried in management tools but there's no effect (dimensions distance even to 1.00 from 7.00 which was default). I've also changed dimension style in prototypes and set 2.5 distance between dimension chains - again, no effect.
Also above is wrong cause I choose extreme and system line in dimension strategy, but I would like to achieve something like this below:
Could someone help me with that? - I can't find points (marked red above) I need to determine the purlin orientation by dimensioning it's webs.
