Sketching in one plane
pedcarson
pedcarson
I have a beginner question - lets say I have a sketch line that I want to draw for a stairs. When I go to draw a slope, the line skews into a 3d plane. How do I constrain it to an x y plane. I also tried creating a custom work plane but couldn’t figure out how to sketch on it?
bigcarl5000kg
Hi @pedcarson ,
have a look at this system variables:
set OSNAPZ = 1
set UCSFOLLOW = 1
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
pedcarson
Thanks - I've set those two values but it still seems to be locked in the xy plane rather than xz.
I've drawn in yellow where I'm trying to go
s_hannemann
u can and should only make sketches in the x-y plane. Before starting your sketch, move the UCS to the startpoint of your sketch. Now rotate the axis till you are in the x-y-plane. U can use your toolbox for these commands.
Now activate the following mode in your tool-box.
U will have a 2D-sketch in your x-y plane. Convert it into a polyline and so on...
I hope that helps.
