Script Error in Label
Julio_Soto
Advisor Advisor
Julio_Soto
I'm trying to write a script for a label for threaded holes.  I just need small holes to be shown as #12, etc., and anything larger as a 3/4" UNC, ect.  My problem comes when I try to use a token in the script that is a fraction. I get this error.
Here is the code
%%script(var = %[20,5,5]Diameter
If var = 0.164 Then
display = "#8 UNC"
ElseIf var = 0.19 Then
display = "#10 UNC"
ElseIf var = 0.216 Then
display = "#12 UNC"
Else
display = "%Diameter UNC"
appendstring(display))
If the unit type for %Diamter is set to decimal then it works. But I don't want decimal, I want fractions with inch symbol.
I think that "Unterminated String Constant" error has to do with the quotation, but I can't get units without the inch symbol even using
Sebastian_Eiche
I think you're right with the fractional idea.
you could output in fractional, but the internal usage is always metric. So why do you change it?
I would try to add a msgbox to let me show, which is the result of %diameter.
If you want to compare it with specific values, you maybe convert the value by using terms like "valuexy/25.4" ?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Julio_Soto
I'm not sure what you mean by a message box.
Also, it looks like %Diamter is formatted to whatever your project settings are set to. For this drawing, it is set to inches/fractions. So to even use %Diameter in the script I have to force it to a decimal value. The problem is I don't have a way of converting it back to a fraction. I googled this topic and it doesn't seem like an easy task. The script looks big and probably not appropriate for this label.
Sebastian_Eiche
with message box I mean, I would use a messagebox to first have a look what the value is about.
I use this to verify if I use the correct phrases like "," or ".", because sometimes it's show in another way later in the label (not often).
In your case I would use a msgbox for diameter:
msgbox var
Sebastian Eiche
Julio_Soto
that can be pretty useful for other things but in my case, it still errors out. If my project settings is set to fractions then %Diameter will cause the script to break and the message box to display nothing.
Interestingly enough if I dont' close the parenthesis of the script as I work it out I can see the result of the tokens.
as soon as I close the parenthesis the script fails for the reason in my original post.
Thanks for trying to help Sebastian. I reached out to Graitec about this and it looks like they will escalate this to AutoDesk. I'm not hopeful. I suspect this is a problem with AS.
Sebastian_Eiche
I think this logical because the unit is using a "
and this is used for defining strings. I would try to delete the last character.
Here's a small example:
%%script(var = %Diameter
var2=Left(var, len(var)-1)
msgbox var2
appendstring(var2))
Sebastian Eiche
