This is an english speaking forum, so it would be nice, if you will create such questions in english please.
To your question:
As I know it's not possible. And from my point of view it is not useable.
Example: you have a screw with a length of 50mm. This screw is used for a clamping length from 20 to 25mm. So this screw is maybe used for a clamping length of 22mm and the same is used for a clamping length of 24mm. To have the clamping length in a bomm list, the screw would need a singlepartnumber for each clamping length they will be used for.
The result would be: you have 10 entries for the same screw in your list.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
