Is there any full sample model for AS?If yes where should i find it.
Solved by múinteoir. Go to Solution.
I had forgotten about those. They seem to be the same 2 examples in every install. So even in the US build they use metric beams.
I wouldn't look at the Industrial Hall model, except perhaps as an example of what not to do. This is clearly ancient. Most of the joints it uses are ancient UK only joints that don't even exist in Connection Vault at all (they were obsolete long before the Connection Vault as invented) and they only have limited options. Other things are modelled manually where they could easily be done with current joints (e.g. purlin layout and purlin joints).
Aleck Giles, Structures Consultant, Graitec
The path is C:\ProgramData\Autodesk\Advance Steel 2021\GBR\Shared\Support\Examples.
Replace GBR with the country code of your choice.
@Anonymous schrieb:folder C:\ProgramData does not exist
You need to set the hidden items in Windows Explorer to visible state:
