Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
sample project
9 REPLIES 9
Message 1 of 10
3631 Views, 9 Replies
sample project
Is there any full sample model for AS?If yes where should i find it.
sample project
9 REPLIES 9
Message 2 of 10
múinteoir
múinteoir
Sample models are stored in the below folder C:\ProgramData\Autodesk\Advance Steel 2019\GBR\Shared\Support\Examples Change the "GBR" section to your local version
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 3 of 10
AleckGiles
in reply to: múinteoir
AleckGiles
I had forgotten about those. They seem to be the same 2 examples in every install. So even in the US build they use metric beams.
I wouldn't look at the Industrial Hall model, except perhaps as an example of what not to do.  This is clearly ancient. Most of the joints it uses are ancient UK only joints that don't even exist in Connection Vault at all (they were obsolete long before the Connection Vault as invented) and they only have limited options. Other things are modelled manually where they could easily be done with current joints (e.g. purlin layout and purlin joints).
Aleck Giles, Structures Consultant, Graitec
LinkedIn
LinkedIn
Message 4 of 10
múinteoir
in reply to: AleckGiles
múinteoir
Didnt know they existed either, just searched to see if it included sample models similar to the way revit includes them.
Message 5 of 10
Yes i found the model.
Message 6 of 10
In the Autodesk folder, I don't see the Advance Steel folder 😕
I'm using the AAS 2021 trial version
Message 7 of 10
AleckGiles
AleckGiles
The path is C:\ProgramData\Autodesk\Advance Steel 2021\GBR\Shared\Support\Examples.
Replace GBR with the country code of your choice.
LinkedIn
LinkedIn
Message 8 of 10
I can't find it, where can i download some sample files?
Message 9 of 10
folder C:\ProgramData does not exist
Message 10 of 10
You need to set the hidden items in Windows Explorer to visible state:
