Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
sag rod end with nuts
8 REPLIES 8
Message 1 of 9
desigan2015
3539 Views, 8 Replies
Dear All,
Please advise how to do the sagrod(roof purlin ) with nuts and washer
8 REPLIES 8
Message 2 of 9
arkli2009
in reply to: desigan2015
One way: use round bar with nut and washer special parts.
Message 3 of 9
desigan2015
in reply to: arkli2009
Dear Arkli2009
i am quite new for AS , please advise how to add like  special parts. please provide is there any video link. Thanks.
Message 4 of 9
arkli2009
Message 5 of 9
arkli2009
U can also download other block use as a special part. As long as it is a pure AutoCAD 3D solid object.
Message 6 of 9
johnjmbennett
There is a macro in the connection vault designed to apply a generic rod section for tie rod purposes, with extensions etc. It was for generic cold rolled.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/screencast/Main/Details/5b2267c9-e...
It was designed so as to add lots of special parts for nuts and washers, because by ordering the tie/sag bar the suppliers of CR have standard opitions to add the fixtures.
John Bennett
Message 7 of 9
desigan2015
in reply to: johnjmbennett
Dear johnjmbennett,
Thanks for the video, also please send me the video of adding  nuts at both end .
Tags (1)
Message 8 of 9
desigan2015
Dear Jhon,
 My projects all in mm. I  have created my 3d nut. when add the nut using special parts , ya its working ,but its scaled automatically 25.4 times. The nut looks so big.
Please advise how to solve this default settings.
Message 9 of 9
johnjmbennett
I believe this is a similar issue to one related to an oversize custom connection joint box.
https://knowledge.autodesk.com/support/advance-steel/troubleshooting/caas/sfdcarticles/sfdcarticles/...
This is related to units in either the custom connection source file or the units in the model file.
Not in advance steel, you have both autocad and advance steel units, you should try and make sure they are all the same type and fractional value.
AS units are found under project settings button, scroll down in the list.
John Bennett
