Hi everyone, how do I add new different concrete column sizes that are round. When i use the command, the only size it gives me is this D80.
Solved by bigcarl5000kg. Go to Solution.
Hi @ABonsall74 ,
easy write there D200 or what other size you need, it is freely editable š.
HTH
Thankyou mate. That works. Never thought to try that.... lol
But why is D200 a 1000 diameter column .... hmmm
However. Now i try and do it again and it wont accept any new values
For concrete parts, the units are in cm. For me it works perfect, even after 10 changes
You enter the diameter, not the radius
If I type in D200, which it let me do, it did create a column as you suggested.
But if I dimension it, it dimensions as a distance of 1000 from centre to edge . So 2000 dia (in mm). So again you are correct.
If i then try and add a new one by typing in D100 for example, it kept saying "profile not found".
I have persisted and now it is working. Thanks for your help
