I am trying to do a plan drawing, with a layout of assemblies like this:
BIG PROBLEM: In the drawing, the round bars don't appear, I was trying many Drawing styles, with different depth values, and none was showing me the bars.
Do you have the same problem with them? Someone told me that he had the same problem also in AS 2022.
Thanks!
Solved by Sebastian_Eiche. Go to Solution.
so what are the round bars, by that I mean are they anchor elements with a square head or are they section profiles with a square plate added.
you would need to know the type of element to then see if it’s drawing presentation could be changed.
very difficult to say without out a simple model to look at.
John Bennett
The detailstyles had to show beams "visible hidden".
Also it seems to be you had clashes between the plate and the beam...correct them (with holes or cut on plate)--> clashes occour the following problem:
The software want to display the beam and get to place, where the clash exist. now the software had to decide: visible or hidden line? and this calculation sometimes bring the software to the point, to show nothing.
If you use double click on the green frame and set all hidden lines to show, do you see it?
Another idea would be: the size of minimal to show parts. There's a default in the management tools for the minimal to show size. If you use 16mm round bars and have a scale of 1:10 the part is 1,6mm on the detail, if the setting in the MT is set to 2mm, the part will not be shown
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Yes, they are made with section profiles. I attach the dwg with it.
