Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Revit to Advance Steel
16 REPLIES 16
Message 1 of 17
Drawtech
1041 Views, 16 Replies
Drawtech
I have an enquiry for detailing some staircases on a large project. (main steel by others)
I have various model files (RVT, NWD, IFC) and 2D drawings with few dimensions.
I can open the Navis file (NWD) to view it but of course cannot open this in Advance Steel.
The Navis model is way too big anyway - I'm only interested in the steelwork and only in the stairwell areas).
I tried the IFC import but nothing at all came through.
Is there a reliable export/import from Revit to Advance Steel?
I don't have revit myself, so would have to be chasing 3rd parties for it - is it worth exploring this avenue?
...so much for BIM 🙄
Dave Gronow
Drawtech Services Ltd
Dave Gronow
16 REPLIES 16
Message 2 of 17
dave_conibear
in reply to: Drawtech
dave_conibear
Dave
There is an Advance Steel Extension for Revit.........you just need to persuade the Revit user to take the time to download and install it if they don't already have it..........and as long as their IT department allows it.
Me, I have had some reasonable success with this, but Revit users seem to have a strange way of inputting steel
members with the system line at say FFL, and then offset the actual member, so you need to go through the whole model and adjust it (if you want to use it for that purpose of course)
And as usual, not all Revit models I have had are accurate, they are able I think to fudge their GA's a lot easier than in Advance Steel.
But hey......that wasn't your question.........I have found the models that I have had via this Extension to import with no problems......and have exported my model back to the Revit user quite successfully.
Dave
Message 3 of 17
acbsdesign
acbsdesign
@Drawtech
Hi Dave,
DO NOT IMPORT from Revit, you will be thousand times better off if you build the adjacent steel supporting the stairs, it will be faster than dealing with all system lines misplaced, and other small but HUGE timewasting bugs around them.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
@Drawtech
Hi Dave,
Message 4 of 17
Drawtech
in reply to: dave_conibear
Drawtech
...so in the imported model from Revit, irrespective of system line position, will the beams be at the correct levels?
Dave Gronow
Dave Gronow
Message 5 of 17
Drawtech
in reply to: acbsdesign
Drawtech
Thanks Ilko. ...that's my usual approach, but the 2D drawings (as they stand now) don't have enough info to re-model  it.
Dave Gronow
Dave Gronow
Message 6 of 17
acbsdesign
acbsdesign
It is funny how they say the import is smooth.
Message 7 of 17
acbsdesign
acbsdesign
And the Revit model will be the center of the design.
What a bunch of schmackos.
Message 8 of 17
bigcarl5000kg
bigcarl5000kg
Hi Ilko,
use the german word "schmacklos" = tasteless  😁😳😉
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Hi Ilko,
Message 9 of 17
dave_conibear
dave_conibear
oh.........sure, they'll be at the correct level, Revit users just seem to have a different way of inputting the members
If you ran a fab' detail directly from that, you would have a system line maybe 200mm or 300mm above or below the shaft, but you don't want the model of that, so it's irrelevant really.
Like I said........it's worked well enough for me in the past.
Maybe others have had bad experiences, but hey........surely it can't hurt to ask if you can have this form of export from your client / engineer/ who ever and try.
If it doesn't work for you then it doesn't work, and you'll know for next time.
Message 10 of 17
Drawtech
Drawtech
OK thanks.
I also just found out the steel contractor for the main frame used Tekla, so any usable export from Tekla could be an option. ...although I've never had any joy with IFC files. Advance Steel always asks to map every section and material and then after spending a load of time it still doesn't import anything!
...anyone know a quick and reliable means to get a Tekla model to Advance Steel ?
Dave Gronow
OK thanks.
Dave Gronow
Message 11 of 17
acbsdesign
acbsdesign
@dave_conibear
Hi, On a model of a two-story building I took from Revit, columns and beams were off, and I moved them at the proper locations.
The real troubles came when starting detailing beams. System lines did not behave as usual despite of being in the right place. Dimension requests started to behave weirdly.
@dave_conibear
Message 12 of 17
dave_conibear
dave_conibear
same for me dave.........I'm sure IFC stands for It's F**king Crap
I'm think X-Steel can export to 3-D solids .ie    .sat......acis or just 3-D .dwg
Have you got a nice friend / colleague with Revit who could open an IFC for you and do it that way? I guess not or you wouldn't be asking.
Message 13 of 17
dave_conibear
dave_conibear
Hi Ilko
I wouldn't disagree with any of that.......not at all
I've only ever used a Revit model for the same purposes as Dave.......when I've had some secondary steel to add in
As you mentioned earlier, I generally bite the bullet so to speak and drop a few dummy beams in and model round that.
But sometimes there is so much existing steel needed coupled with no available information on paper or 2-D last thing on a Friday, you get squashed between a rock and a hard place and have to take what you can get.
Hi Ilko
Message 14 of 17
Drawtech
Drawtech
Thanks for your input guys.
I think best bet will be to get 3d dwg from the Tekla model.
Dumb solids that at least are in the right place and I can open in Advance Steel.
BIM at its finest!
...so glad they spend so much time developing all this useless crap at the expense of proper detailing functionality! 🙄
Dave Gronow
BIM at its finest!
Dave Gronow
Message 15 of 17
acbsdesign
acbsdesign
@Drawtech
Well said, as always.
I can only wish they had people like you there.
Happy Friday.
@Drawtech
Happy Friday.
Message 16 of 17
AleckGiles
AleckGiles
Hi Dave,
If oyu want to iport form tekla we reocmmend usign hte CIS.2 format. It is slightly better than IFC.
First, make sure they set the export options to something like "Fabrication model" and not "Design model" or something like that. Telka tends to export everything as useless Boundary Representations that cannot be imported. It can export intelligent objects if they twist its arm a bit during the export.
When you import you will most likely have to wade through umpteen questions to map section sizes and materials. This is an annoying pain. There always seem to be more questions than beams but that is how it is. Persevere and eventually, you can end up with a very good import of their model with all beams placed accurately. No guarantees though of course 🙂.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Hi Dave,
LinkedIn
Message 17 of 17
Drawtech
in reply to: AleckGiles
Drawtech
hmm.
Thanks, but I have played that game many times - spending the best part of an hour mapping everything only for the import to fail.  ...then all the mappings do not seem to get saved anywhere and has to be done all over again every time.
It's such a painful prodedure and rarely works.
...why hasn't Autodesk already mapped everything in a database table for importing from other popular softwares?
At least then if the import doesn't work, you have not wasted a load of time mapping everything.
Dumb 3D solids still seems the most reliable way to get the geometry and just re-model over the top!
Dave Gronow
hmm.
Dave Gronow
