Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
RED AXIS LINES IN SHOP DRAWING
5 REPLIES 5
muleman1
3428 Views, 5 Replies
Anyone know how to turn off the red axis lines in shop drawings. I have searched the drawing styles manager from one end to another and cannot find any reference to the red axis lines that show up as profile center lines in the shop drawings.
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
5 REPLIES 5
in reply to: muleman1
In Advance Steel these lines are called System Lines and can be turned off in Objects "Presentation" as seen below.
Alternatively, you can modify this within a created drawing in the "Advance Properties" dialogue, within the "Axes" tab and by unchecking the "System Line Color" check box.
muleman1
Thank you very much ! This solved the problem. However, when I turn off the system lines, we loose our centerline chain dims of the pickets. We played with different settings and 'enviroment' places a faint line on the dwg to allow the chain dims. THANK YOU FOR TAKING TIME TO HELP US! Maybe one day Autodesk will release complete help manual or at least fix the onboard help system and we won't have to bother people who are trying to work. Thanks again
Is there a way of filtering or multi selecting these red axes for removal en mass?
johnjmbennett
In the model , no you cannot remove them, they are the main wire reference for the object body .
You can change the object presentation so the done show, think that is exact with weld preps, under display tab.
You can use filter tools on palette to select all beams in model at once.
In drawings, for example GA/overview type, you could select one bean, then select similar , the right mouse click to see the advance properties, then under the system line, you can turn off or change colour.
If you wish different colour all the time then change in MT defaults, search for colour, then system line and change .
John Bennett
A.Tusia
in reply to: johnjmbennett
I tried this solution and the red system line still comes in as red.  Which can't be frozen or the color changed.   Can color of this system line in Autocad drawings be changed in Autocad level and not at the sheet level?
