Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Railing Joint Handrail
4 REPLIES 4
mick-CNF
462 Views, 4 Replies
mick-CNF
Is there a way to set the default weld to be site for this?
When I change this in MT nothing changes when adding the joint.
If this information solves your problem please accept as a solution.
4 REPLIES 4
Sebastian_Eiche
in reply to: mick-CNF
Sebastian_Eiche
set the connection as you want, press "save" in the library. Then go to "edit" in the library category, delete the first line and rename your setting to "default"
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
mick-CNF
in reply to: Sebastian_Eiche
mick-CNF
Smiley Very Happy That's exactly what I did just before your reply.
alickomay
alickomay
i use this save as default method  for lots of macros /connections it should work
i even use it for my rail macro
mick-CNF
in reply to: alickomay
mick-CNF
Yes, now I know you can do it this way it is far better than messing around in MT.
I altered my ladder defaults in MT and it worked OK, when I tried to do it with the railing macro it went wrong, badly.
I'm going to try it with railings and stairs now.
