Is there a way to set the default weld to be site for this?
When I change this in MT nothing changes when adding the joint.
Solved by Sebastian_Eiche. Go to Solution.
set the connection as you want, press "save" in the library. Then go to "edit" in the library category, delete the first line and rename your setting to "default"
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
That's exactly what I did just before your reply.
i use this save as default method for lots of macros /connections it should work
i even use it for my rail macro
Yes, now I know you can do it this way it is far better than messing around in MT.
I altered my ladder defaults in MT and it worked OK, when I tried to do it with the railing macro it went wrong, badly.
I'm going to try it with railings and stairs now.
