Announcements
Purlin section default?
Dias_Antonio
Dias_Antonio
Hello Guys
Firstly Merry Christmas to All...
I am trying to model purlin in a structure and I need a customized section that I have created previously...
When I model the purlins there is no the section that I have created...
I accessed the Mnagenment Tools and used the filter (typed purlin) to change the default sections for purlins and I did not found it...
I am confused with this...I restarted the program and I am with this issue
Where is the property that controls the section default for purlins?
See atachment...
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
Replies (7)
johnjmbennett
If you are using the purlin SE macro, from the structural elements panel on ribbon home tab.
You our need to go to the database table gui allowed sections, found in Astorrules database ( via management tools) table editor. In there you need to add the user section reference to the purlin se rule.  If you look , there are existing references for other user profile definitions like “Albion, metsec”
this is process is the same as adding sections for railing, stair stringers, which you will find YouTube reference, AKN articles.
Make sure you use the section name type, not the profile type, the profile type is for standard sections like channels, beams, angles etc.
John Bennett
johnjmbennett
https://forums.autodesk.com/t5/advance-steel-forum/new-type-purlins-for-macro/td-p/5313327
Try link, previous reply, same process still now.
John Bennett
Dias_Antonio
John
Thank you very much for reply. I followed all the process and unfortunatelly I did not get use (insert in database) my users profiles that I have created previously.
I will go on trying. Thanks a lot !!
Antonio Dias
jonous
Hello. Can someone show me where exactly this field can be found in the AstorRules section?
Thank you in advance.
AleckGiles
This is ht etable you need ot add your purlin seciton to in order ot use itin the Purlins joint.
Ass a new line similar to the ones showing.; remember to use the proper TypeNameText for your section, not the user name. For example, if you have defined a user section called MyUserSection the TypeNnameText would be "Usr MyUserSection"
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
jonous
You're awesome, thanks!!
hugo_ferLuna
  • Usa la Palabra  "Andere
  • For "Section shape", use the letter "O" for tubes, "W" for all angles, "Andere" for "User section".
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
