Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
problem with connection
6 REPLIES 6
eyal.ch
379 Views, 6 Replies
eyal.ch
hi all,
I can't create the connection of gusset plate to column and base plate. like in the picture below.
I picked the command (marked in yellow) picked the column and the plate and the C purlin,
and I get this message:
what is it? and what is the problem?
Thank you
hi all,
Thank you
6 REPLIES 6
steve.bekkers
in reply to: eyal.ch
steve.bekkers
its a bit hard to see what is going on?
Sebastian_Eiche
Sebastian_Eiche
a sample model.dwg would be good
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
mick-CNF
mick-CNF
Hi @eyal.ch
As @Sebastian_Eiche can you attached the model to see what is happening?
It is working OK for me unless yours is different?
If this information solves your problem please accept as a solution.
Hi @eyal.ch
AleckGiles
AleckGiles
If the Magenta beam is the "Diagonal Beam" selected for the joint it won't work because it is not diagonal it is perpendicular to the column. It likely results in a divide by zero or something in the code.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
LinkedIn
steve.bekkers
steve.bekkers
is this what you are trying to do?
eyal.ch
in reply to: AleckGiles
eyal.ch
Thank you all,
@AleckGiles  - thats right, it solves the problem.
Thank you all,
