I wanted to update my drawings.
When updating, Advance Steel has changed the names of all plates whose dimensions correspond to a flat bar from plate to flat bar. How can I undo this?
Solved by bigcarl5000kg. Go to Solution.
When I create a plate 20 mm thick and 200 mm wide, advance steel automatically names it FL 200x20.
When I create a plate 20 mm thick and 213 mm wide, advance steel automatically names it PL 20.
Where can I find the settings for it?
It depends what you want?
If you never want plates to be made from standard flat bar when it can uncheck recoding in MT.
Must be different for your language installation.
maybe Mapping 😉🤟
