Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Plate Names
6 REPLIES 6
maebingerEX3UQ
341 Views, 6 Replies
Plate Names
I wanted to update my drawings.
When updating, Advance Steel has changed the names of all plates whose dimensions correspond to a flat bar from plate to flat bar. How can I undo this?
6 REPLIES 6
When I create a plate 20 mm thick and 200 mm wide, advance steel automatically names it FL 200x20.
When I create a plate 20 mm thick and 213 mm wide, advance steel automatically names it PL 20.
Where can I find the settings for it?
It depends what you want?
If you never want plates to be made from standard flat bar when it can uncheck recoding in MT.
If this information solves your problem please accept as a solution.
Sorry, but I can't find the setting.
mick-CNF
in reply to: maebingerEX3UQ
Must be different for your language installation.
maybe Mapping 😉🤟
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Yes.  mapping.
That's it.  😁
