Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Pins as Bolts Workaround
4 REPLIES 4
s_hannemann
260 Views, 4 Replies
i am looking for a way to generate standard pins, by using the AS tool for screws, anchors, holes etc.
Problem is, i cant generate a screaw without the head. It always wants some details about the dimensions etc..
At the moment i need to insert every pin as special part. This method is not good in my opinion. The Pin and the hole have to be intelligent connected, always.
Did somebody found a good method to insert intelligent pins in AS? All i need is a standard round object connected to the hole and with BOM usability.
4 REPLIES 4
acbsdesign
in reply to: s_hannemann
@s_hannemann
We can use any bolt, No Nut No Washer:
The head diameter is equal to the shank diameter.
This is the same bolt with nut and washer, and no head:
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
s_hannemann
in reply to: acbsdesign
thanks for the quick response. I cant change the diameter in the mask. I dont know why. Is it fixed by some other option or what am i missing?
s_hannemann
I am stupid.
Had to copy from an existing bolt and i was able to change the mask.
acbsdesign
@s_hannemann
LOL, no one is stupid here.
