i am looking for a way to generate standard pins, by using the AS tool for screws, anchors, holes etc.
Problem is, i cant generate a screaw without the head. It always wants some details about the dimensions etc..
At the moment i need to insert every pin as special part. This method is not good in my opinion. The Pin and the hole have to be intelligent connected, always.
Did somebody found a good method to insert intelligent pins in AS? All i need is a standard round object connected to the hole and with BOM usability.
Solved by acbsdesign. Go to Solution.
We can use any bolt, No Nut No Washer:
The head diameter is equal to the shank diameter.
This is the same bolt with nut and washer, and no head:
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
thanks for the quick response. I cant change the diameter in the mask. I dont know why. Is it fixed by some other option or what am i missing?
I am stupid.
Had to copy from an existing bolt and i was able to change the mask.
LOL, no one is stupid here.
