Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Part marks for identical pieces
5 REPLIES 5
HarryHighpants
293 Views, 5 Replies
I've got two seemingly identical brackets.
I've checked that the material is identical, even run the command that checks differences.
When I run numbering, they receive different prefixes despite having the same model role (bracket plate).
Anyone know what the culprit is?
5 REPLIES 5
The hole in the vetical plate with a bevel on it seems to be different, and the centre mark / cross hair for the back plate seems to be in a different place.....is it that maybe ?
That's not a hole, its just a cross hair that gets created when you join two plates to make one folded one.
No idea why the cross hairs end up in different places. The beginning plates are identical (they are copied).
múinteoir
in reply to: HarryHighpants
Can you check if you have 'Unique single part numbers' ticked in Management Tools > Defaults > Numbering > General?
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
HarryHighpants
in reply to: múinteoir
These are the settings I use:
Could you please attach the model with these elements, to take a look ?
Best regards,
Emy
Emy Nestor
