Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Beam features filtering
3 REPLIES 3
lk
229 Views, 3 Replies
I have tried to filter "corner cuts" of the beams with "beam features" filter. It seems that it doesn't work in AS2016. Do you have the same issue?
Is there any way to filter this type of cuts?
I think the same issue is with "bevel cuts", there is no way to filter those kind of features.
Leszek K
3 REPLIES 3
ZHUKOV_ING
in reply to: lk
theese are not  corner cuts on the beam... Try with plate features filter :D...
lk
in reply to: ZHUKOV_ING
Unforunatelly those are flat bars not plates and the filter "plate features" doesn't work too,
Leszek K
Emanuel.Nestor
in reply to: lk
Hi Leszek,
You might try in this way:
- select one corner edge feature
- right-click and choose the option Select similar
As result, all these specific features (beam corner cuts) will be selected.
Best regards,
Emy
Emy Nestor
Technology Administrators
