Output DXF with Same Single Part Number but Different Contour Marking
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to setup the NC Settings to output my plates as dxf files with contour markings on them for easier fabrication in the workshop. The problem I am getting is that I will have a model with multiple plates that have the same single part number but have different contour markings and when i export the dxf files some of the plates are not created (or are written over) and also the QTY's are incorrect.
See screenshot of my model which shows 4x plates. Please note the plates on each end of the beam will have different contour markings because of the placement of the plate in relation to the beam. The other 2x plates should be the same because they both have no contour markings. In total I would like to output 3x different dxf files for the plates in this scenario showing the correct QTY's in the file name.
I have also screenshot my NC Settings and the output files I am currently getting when i run the DXF's for plates. Please note the QTY's are also wrong as it adds up to a total of 5 plates.
