Hi all, does anyone know what the option is for inside the red rectangle that is in Arrange in Center options and is inside the Prototype Layout detail? Thank you.
Dear Colleague
Depends on your (Paper Space). The size of you sheet, the amount of detail on it...
Att
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
With what you tell me, I have not managed to understand well what that option does.
But, thank you very much for the help attempt.
