I am trying to "Insert a Details List" on a sheet containing an Overview Drawing for a Staircase with Railings. The idea is to show in the list only the elements that is contained in the view.
According to this article it is possible if the detail style uses the Detail box or Detail box with Xrefs option: https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU...
I have set the Model Object Selection in my Detail Style to this option but it will still show elements in the list that is not part of the view. as can be seen in the images.
For testing I have used a Camera with the "1.5 - Elevation (Full)" detail style in the International Category assigned to the Camera Properties. I have however also tried to create the view by applying the Style directly to the model in the XY plane.
Kind Regards,
Sampie
_______________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
youtube.com/prokonbuild
