.NET Connection in VB.NET
spayne76BBK
spayne76BBK
I've recently had success with creating a .NET Joint in C#.  I am now trying to create the same code using VB.NET.
I ran into the same error code I was getting when I was trying to create a C# .NET Joint. (The thread I am referring to is Issues with Advance Steel Walkthrough - .NET Connections )  In the end, it turns out that I was using the wrong class library template in Visual Studio.
I have verified that I am using the .NET Framework 4.7.2 for this project; the same as the C# project and I believe I am using the correct class this time.  However, I get the following error when I try to run the code.
This seems to be a generic error. Trying to debug this doesn't seem to work as the Query subroutine is not running before the error is generated.
Does anyone know if it is possible to write a .NET Connection in VB.NET? Or, does it have to be a C# program? I can't find anywhere that would indicate that this is the case. I am assuming that they both produce the same result when they build/compile the project into the *.dll file. (Maybe I am wrong?)
There are some differences I have noted between the way the IRule interface is implemented in C# vs VB.NET. Below is the C# and VB.NET code that gets generated when you add the IRule interface to the class.
C# Code:
using System;
using Autodesk.AdvanceSteel.ConstructionTypes;
namespace MyNetJointInterface
    public class MyNetJoint : IRule
        public Autodesk.AdvanceSteel.CADLink.Database.ObjectId JointId { get => throw new NotImplementedException(); set => throw new NotImplementedException(); }
        public void CreateObjects()
        public void GetRulePages(IRuleUIBuilder builder)
        public string GetTableName()
        public void Load(IFiler filer)
        public void Query(IUI ui)
        public void Save(IFiler filer)
VB.NET Code:
Imports Autodesk.AdvanceSteel.CADLink.Database
Imports Autodesk.AdvanceSteel.ConstructionTypes
Namespace MyNetJointInterface
  Public Class MyNetJoint
    Implements IRule
    Public Property JointId As ObjectId Implements IRule.JointId
      Get
        Throw New NotImplementedException()
      End Get
      Set(value As ObjectId)
      End Set
    End Property
    Public Sub Query(ui As IUI) Implements IRule.Query
    End Sub
    Public Sub CreateObjects() Implements IRule.CreateObjects
    End Sub
    Public Sub Save(filer As IFiler) Implements IRule.Save
    End Sub
    Public Sub Load(filer As IFiler) Implements IRule.Load
    End Sub
    Public Sub GetRulePages(builder As IRuleUIBuilder) Implements IRule.GetRulePages
    End Sub
    Public Function GetTableName() As String Implements IRule.GetTableName
    End Function
  End Class
End Namespace
I have attached the working C# implementation and the translated VB.NET code.
spayne76BBK
I've managed to figure out the issue. Visual Studio handles namespaces a bit differently depending on the programming language you choose; in this case VB.NET and C#.
In C# the default namespace in a Visual Studio project determines the initial namespace added to the top of the file for each new item added to a project. It does not get appended to the front of the namespace during compile.
In VB.NET it's a different story. The Root namespace is added to every namespace in the project when it is compiled.
The class below will compile to MyNetJoint.MyNetJoint.MyTestJoint
  Public Class MyTestJoint ...
End Namespace
 Whereas the code below will compile to MyNetJoint.MyTestJoint
    public class MyTestJoint ...
I managed to figure this out while I was trying to read the Common Intermediate Language (CIL) created by the two different languages. (VB.NET and C#)
I used ILSpy ( availble at GitHub and/or Visual Studio Marketplace) to read the CIL and noticed that the MyNetJoint written in C# had a difference namespace where the MyTestJoint class resided. (The first MyNetJoint in the list is the C# dll and the second MyNetJoint in the list is the VB.NET dll). After adjusting my VB.NET dll to have the same namespace as the C# dll, Advance Steel was able to run my .NET Joint.
I did some additional digging to see if it was best practice to omit the Root namespace from the project, or to leave the Root namespace as is and remove the namespace from each of the *.vb class files.  In the end, it seems that common practice is to leave the Root namespace blank in the application settings and to specify the namespace in each file. I believe this is standard practice in C#, (explicitly  defining namespaces), however, in VB.NET I can blissfully start writing code without having to define a namespace. Only to end up in this very predicament; chasing down nested namespaces. 😒
I have attached the updated code for anyone to use in the future.
