EXTRUDE CUT ALONG POLYLINE
JACK.BOOTH5
JACK.BOOTH5
Hi all, I have a question regarding the best way to extrude a non uniform profile such as the one attached picture. It will be a concrete feature that doesn't have significance in my model but I would like to include it for appearances. Is there a way to extrude the sketch directly, or failing that how do I create an extruded cut along this poly line through a solid extruded object. Thank you!
JACK.BOOTH5
I answered my own question by creating two solid extrusions and then the subtract command
robertwmerriman2
Hi @JACK.BOOTH5
You could have also modelled the conrete as a concrete slab then used the polygon contour command to cutout the polyline Concrete slab with cutout.PNG
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
