Tube connection
Tube connection
MRizea
Message 1 of 14
Tube connection
MRizea
Hi everyone. I have a bit of experience in using AS and I found a nice connection to try and replicate.
I started by using the connection "Tube end to end", but I don't know how to make the small cuts for where the bolts should fit. Any ideas?
Thanks in "Advance" 🙂
Replies (13)
Message 2 of 14
bigcarl5000kg
it probably won't be thick-walled pipes, it looks like welded flanges, but maybe I'm wrong...😉
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 3 of 14
bigcarl5000kg
Here two solutions (see DWG attached):
- as welded flange on tube
- as thick walled tube
Your solution depends on the actual implementation, which unfortunately was not described.
HTH
Message 4 of 14
MRizea
Thank you for your examples. It looks very good. I tried using a thin wall tube and adding verical plates for the cuts and cap of holes, but I could not model a vertical rounded plate 😞
Is that even possible?
Message 5 of 14
bigcarl5000kg
to get the right direction for a plate, you need first to set the UCS with Z-axis perpendicular to the plate surface as needed.
I would say that your flanges are either forgings or castings that were welded onto the tube.
That's why the screw pockets in your photo have that shape. It can probably be made from thick sheet metal, with a slightly different pocket shape. Then just weld it to the front of the tube and you're done. In my example, I also used a round profile welded to the tube.
Post some photo here, if it doesn't work for you.
Message 6 of 14
MRizea
I created plates pependiculat to the flanges, but they are only straight ones. I don't know how to create perpendicular plates that are rounded or that can follow a polyline 😞
Message 7 of 14
bigcarl5000kg
Create a polyline (circle):
Have a look at the possible commands for plates - you will find this one (_AstM4CommPline2Plate in command line):
Go through all panels and commands, test / train / gain experience
Message 8 of 14
MRizea
I tried that and the result I get is a circular plate and not a vertical one.
I also tried creating a vertical plate following a polyline by using the Beam,Polyline and Beam,From Line commend but none of them are working.
Message 9 of 14
MRizea
I also tried creating a vertical plate following a polyline by using the Beam,Polyline and Beam,From Line command with a FLAT profile, but none of them are working.
Message 10 of 14
bigcarl5000kg
I don' understand, what do you really want.
Create polylines with different UCS or rotate them to the UCS as needed:
Use the tool to create plate from polyline:
Edit the plates thickness and  use further as you need.
You can try to train the basic commands (object creation, object manipulation) for 2D / 3D objects in AutoCAD, which are naturally also available in Advance Steel.
Message 11 of 14
bigcarl5000kg
To get the right UCS, use the tools from Advance Tool Palette:
Message 12 of 14
MRizea
Maybe I didn't explained it well enough. What I wanted is to create a vertical plate with this shape. The one in the picture I created using simple Acad polyline contour and extrude.
Message 13 of 14
bigcarl5000kg
Create polyline:
Two options
1) Create beam on polyline = polybeam (eg. flat):
or
2) Create user section beam (plate):
Look in command line for the inputs / definitions and for possible options too.
Message 14 of 14
MRizea
Thank you and also thank you for your patience 🙂
