Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Multiuser connection to Master model
1 REPLY 1
547 Views, 1 Reply
I created Master model on my network drive and then I created local copies on 3 computers. Copies are on hard drive. On one computer I can connect to master model, but on other two I cannot. When I try to connect I get warning message like on attached picture.
Can someone help me to solve this problem?
Thank you
1 REPLY 1
johnjmbennett
just to to check you are aware of the help pages on this topic.
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU...
Also check the properties for connecting, found sometimes this not set up correctly on different machines, by user profile and permissions etc.
"Open the file properties dialog for this DWG file (right click on the file > Properties). Then go to the Security tab to change the security settings for this file, like in the image bellow.
Note: It's necessary to check the option: "Include inheritable permissions from this object's parent". If this option is turned off then all the added users that should have access to this file will be automatically removed from the allowed access list for this file."
cheers
JB
John Bennett
