Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
MODEL IS NOT OPENING
5 REPLIES 5
anshulgupta861
480 Views, 5 Replies
Hello experts see attached model, last evening i complete my work
and today i am not able to open that model. Please have a look at it
and show me some possible results asap. I need to submit it tomorrow.
Otherwise i have to rework.
Any help will be appreciated.
5 REPLIES 5
I could not open it too.
have a look in your temp folder of windows:
Have a look for your modelname (could be file extension *.bak or *.sv$) take file and copy it to your model folder. rename the fileextension to DWG. If you take the same name, like your model, all details and so on could be attached
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
It works👍
Thank you so much @Sebastian_Eiche
Tags (1)
made some tests. if you open the dwg AutoCAD said, the file has to recover...and then I thought the software broke, but it only take time, after 10 minutes the drawing is recovered 😃
Sebastian Eiche
and now I maybe have an idea, what is problem...You move your object maybe a bit far away from the AutoCAD Word coordinate 0,0...AutoCAD is not unlimited 😁
Sebastian Eiche
and additonal:
do an audit:
After audit moving the model, the file is smaller and much faster...not sure if move all objects correct.
Sebastian Eiche
