Dear colleagues,
Can we set the labeling setting to hide the naming part as rectangular highlighted in pic 1? and can we show the bolt assembly label which include nut and washer in callout view ?
You would need to create a custom drawing style with different labelling rules , basically set it to not label those elements.
the bolt again you would need to create a specific label type to shown this and set it to label the bolt etc.
backup your astoraddin before making any changes to the drawing styles. Also use the copy not deep copy option.
there are lots of videos out there on the subject, it is a complex subject , not easily adjusted in a forum answer, to many variables
John Bennett
maybe additional to @johnjmbennett
You could also delete the automatic labels and create manual labels with your settings. The way John wrote is definitely the better one, but to get a fast result, manual lables are an option.
For the manual label adjustment, press "insert label" then press "C" for change. Right mouse click in the User area and then "set as current". Now you could change all your labels.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
