Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Missing Hole Definitions
2 REPLIES 2
411 Views, 2 Replies
I am working on a project and it involves inserting quite a few holes in straight and curved beams. When I create the holes they have the green gizmo that allows for removal and or changing the properties of the holes. After awhile the gizmo vanishes, the hole remains  and I can no longer alter or remove the hole. Some holes retain the gizmo and all is fine.
Has anyone had this issue and is there a solution, a setting or am I just doing something wrong?
2 REPLIES 2
wtheron
Hello Grinvent,
Can you try to change the beam representation to features?
in reply to: wtheron
This was discussed during training and I forgot all about it. Yes, it does appear when changed to features.  There is so much to learn and remember and coming from another package doesn't help.  Thanks for your reply.
