Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
MAKE AN ASSEMBLY
1 REPLY 1
761 Views, 1 Reply
MAKE AN ASSEMBLY
Good morning,
In AS, It is possible make an assembly with all the pieces of the 3D? I mean, If I have to move a lot of pieces, It is better to move once than been moving piece by piece.
I don´t know If doing that is possible, but if it would possible, please, explain me how to do.
Thanks for your help.
MAKE AN ASSEMBLY
Good morning,
1 REPLY 1
AleckGiles
AleckGiles
You cannot make "assemblies" in Advance Steel like sub-assemblies in Inventor or similar. The assemblies in Advance Steel terms are to do with connecting objects in the workshop - i.e. fabrications. They won't help your editing.
You can use ordinary AutoCAD object groups if you like. These can help you to easily select sets of items. Icons for these can be found in the "Output > BOM on Drawings" ribbon panel.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
LinkedIn
