Dear expert,
In my model portal frame assembly mark marked PF-1. Here, column is fixed main part. Another parts are attached single part.
In GA drawing i will labeled main part mark column as PF-1
Can i call main part mark through attached single part?
Solved by Sebastian_Eiche. Go to Solution.
Management Tools: Default: allow singe part labeling with their main part numbers
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Dear,
Ok. But, result came this...
so this singelpart is attachet not to only one MP, the list will always show all MPs
Sebastian Eiche
Dear,
Yes. this part came in all assembly.
another workaround would be, to transmit the Mainpartnumber in another token like Userattribute1 and then label this token
Sebastian Eiche
