Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Main part mark
5 REPLIES 5
S.MANICKAVASAGAM
275 Views, 5 Replies
Main part mark
Dear expert,
                In my model portal frame assembly mark marked PF-1. Here, column is fixed main part. Another parts are attached single part.
     In GA drawing i will labeled main part mark column as PF-1
     Can i call main part mark through attached single part?
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
5 REPLIES 5
Management Tools: Default: allow singe part labeling with their main part numbers
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
Dear,
          Ok. But, result came this...
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
so this singelpart is attachet not to only one MP, the list will always show all MPs
Sebastian Eiche
Dear,
         Yes. this part came in all assembly.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
another workaround would be, to transmit the Mainpartnumber in another token like Userattribute1 and then label this token
Sebastian Eiche
