Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
License checkout timed out
5 REPLIES 5
advandes
11879 Views, 5 Replies
advandes
A few days ago I downloaded the latest 2020 Advance Steel Software, completed a project without issue in about two days and this morning when I went to start another project, I keep getting this horrible notification that is keeping me from using the software. Please see attached screen capture. I read a number of threads in various forums and would have to hire an IT person to figure out what to do. Does anyone have a simple solution that solves this issue? thanks!
AAG
Advance Design
AAG
Advance Design
5 REPLIES 5
Sebastian_Eiche
in reply to: advandes
Sebastian_Eiche
Are you sure you add the product in your account to yourself?
I would try to reset the licensing by to doing the following:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Forcing-re-activation-of...
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
advandes
in reply to: Sebastian_Eiche
advandes
I never changed any of my account settings and everything is assigned to me as it always has been. I rebooted the computer and it seams to be working now. Must be another bug... lets hope it doesn't happen again. Thanks
AAG
Advance Design
AAG
Advance Design
lovecraft
lovecraft
Have you seen this?  I had the same problem and this appears to fix it.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
LC Smiley Wink
LC Smiley Wink
advandes
in reply to: lovecraft
advandes
I have not seen that. Thanks. I have not had that issue return....yet.
AAG
Advance Design
AAG
Advance Design
SimonBSamuels
SimonBSamuels
The new licensing policy has left me with completely unusable AutoCAD programs - basically I now have to re-install every single one - had 'Support' on Team Viewer for 30 minutes trying to fix the problems - they then gave up and ran away..........
