@pawelpiechnik
@Drawtech
I completed a 3 day course with Revit, including import of steel connections and working with families.
I also called 2 respectable Engineering offices with request for comment about having connections done in Revit.
The bottom line is: Engineers DO NOT WANT to do the connections, it is time wasting procedure for them, and usually fabricator (detailer hired by the fabricator) will do them per their standards and common practice rules.
First of all-designers and detailers have to be one company in order to do it.
Second-connections are done far easier in Advance than in Revit.
One Engineer said-he did connections only between two beams in order to show typical connection for the entire project.
Beams are usually created with Beam System option in Revit for massive large floor plans, and in order to create an Advance Steel connection we have to explode the Beam System.
Dealing appr. 24-28 hours now with Revit, and calling around led to the following conclusion:
-Engineers are not willing to provide model having all beams and columns and bracing, etc., pour stop, shear studs, lev. plates, anchors, ... done
-Engineers are not willing to provide model done with connections
-Please watch this video and try not to laugh ( I can't stop laughing)
-it is a complete waste of time for something we do not want, and we do not want to pay for.
Have fun:
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/classes/year-2017/revit/msf122200#c...
Talk to your supervisors, and get on track with your competitors.
I believe Advance Steel can be the best overall software for steel detailing-you have the budget, we have the desire to help and make suggestions, report bugs etc.
The only thing that is really missing-a full desire to head 100% towards improvement in the overall steel detailing process.
Find the "bottlenecks" of the following main steps:
- Modeling-where the modeling slows down. Take Railing macro for example-we cannot explode it into 6-8m (20') sections-there are 13+ lines in the idea station. Moment connections-most of them are not even mentioned in your connections vault-ref. the idea station.
Take the missing anchor bolts / threaded rods macro-is it so hard to make a macro that will help us? Number of nuts / washers/ thread length, hook info-ref. idea station
2. Numbering-how is the numbering done-(sadly not per shape, plate thickness etc.-we cannot output a decent Advance BOM with preliminary numbers and material sorted without wasting time to select each size and run the numbering)
3. Any further improvements in drawings styles
3.1. Beams are almost perfect--copes can create multiple dimensions to be cleaned, instead of only two dimensions, otherwise overall are o.k.
3.2. Columns-drawing style is perfect if we have a simple base and cap plate and shear plates. Having moment connections and skewed shear plates-this is a heart-breaking disaster.
We also need work planes somehow referenced in column drawings. (T.O.S. let's say 3" above first hole of a shear plate) And possibility to differentiate galvanizing holes form regular holes.
Any dimension referenced to outer edge of a W-column shall be eliminated-this is a rule. Your Product Manager does not know this, and did put my idea in the archives, but it is a very common practice.
3.3. The way now we create sections in erection plan / elevations and send them to other drawings-it is a WWII process. No link between section done on one drawing and shown on another drawing, it is very primitive-have a look at Revit-it is done with automatically labels and call-outs, updating between drawings sheets if section view number is changed or deleted.
3.4. Cameras-well-these are great, but not there yet-ref. idea station
3.5. Cloning modifications of one detail to another-one of the best ideas so far-ref. idea station @iwafb
3.6. Documentation for drawing styles sucks-especially about the default dimension requests.
Only a Two part video done in YouTube, with " AHMMMM, HMMMMM, MHHHHH, HmmmmHmmmmm, Aaaaaaaa, ......come on guys-no one to make a professionally presented video?
The best represented video was so far done by @bukko
A real user shared very helpful ideas-bring more of these so we can all benefit
4. Drawings clean up-now dimensions are more stable (THANK YOU) and labels (fingers crossed ) won't move (THANK YOU).
Section views in beam and column dwg styles-these regenerate and move during update, and it may get ugly on some dwgs.
Section View Labels move upon update.
5. Document Manager-This Fellow needs an overhaul-Ref. Idea Station. Batch plot lists form document manager, choose destination folder for plotting etc.
6. But not last-MARKETING-where the hell is the Marketing?
It is not here-some fabricators have never heard about Advance Steel.
What happens here is the users make the advertisement, not your Marketing Director.
Yours is probably talking about VR and AR in LinkedIn.
No advertisement in AISC Modern Steel Construction-not a word.
Regards
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
