Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Incorrect labels on GA drawing
7 REPLIES 7
Message 1 of 8
tmccar
305 Views, 7 Replies
When I do a numbering on my steel frame structure, the part marks are showing as "NONE1", "NONE2" etc..
And on the GA drawing, wher I would like to have the member description (e.g. RHS50x3), all I am getting is "3x NONE2", "2x NONE3" ETC. How can I correct the label settings?
Tags (1)
Labels (2)
7 REPLIES 7
Message 2 of 8
mick-CNF
in reply to: tmccar
You need to have a model role set, most of the time this is set for you in the macros.
The label is a token.
Screenshot 2024-06-05 131523.jpgScreenshot 2024-06-05 131605.jpgScreenshot 2024-06-05 131648.jpgScreenshot 2024-06-05 132043.jpgScreenshot 2024-06-05 132115.jpg
If this information solves your problem please accept as a solution.
Message 3 of 8
tmccar
in reply to: mick-CNF
Sorry - how do you access those settings?
Message 4 of 8
mick-CNF
in reply to: tmccar
In the model you can right click the item and advance properties or double click the item.
In the drawing its pretty much the same, jsut a few different options when right clicking.
Message 5 of 8
tmccar
How did you get the "Advance Steel - Labels and Symbols" dialog box?
Message 6 of 8
mick-CNF
in reply to: tmccar
Right click or double click the label.
Message 7 of 8
tmccar
Thank you - how can I avoid doing one at a time?
Message 8 of 8
mick-CNF
in reply to: tmccar
You can select as many labels as you like but keep them similar, so don't have a mixture of beams and bolts.
If you do select multiple labels the text box will appear blank if they are different section sizes but the part name token will add the correct section size for however many labels you edit.
Technology Administrators
