When importing a model from Revit is there a way to avoid the positioning differences and if not is there an easy way to modify all the beams with different Z values once imported?
[ The subject line of this post has been edited for clarity by @pendean Original: Importing ]
Hi @mick-CNF
This is the way the Revit user has modelled the beams, in Revit you can have the system line locked to a level and then offset the physical beam. This is done with the Z offset value. If they create it this way then when importing thats what you get in Advance Steel.
In Revit you can change this value to 0 and instread use the Start and End offset values, this will give the physical and analytical model in the same location.
To change this globally in Revit you can setup a schedule to show only this information and you can actually modify the schedule and it will update the model
Rob Merriman, AEC Technical Lead, Graitec
Hi @mick-CNF
Hello, it seems to not be related to this parameter in revit.
i've these problems between RVT24 & AS24
see below:
Revit:
and advance steel 2024:
my revit elements are in fabrication form.
i did not succeed to get the same Z justification between revit and AS.
see below:
Revit:
Hi. If you isolate that beam in Revit and copy to a blank project and purge, you can share it here and we can test it. I have not had any issues like that with the 2024 Revit and Advance steel workflow
