Importing a Bill of material into a fabrication drawing
After creating a Bill of Materials (ex bolts, nuts, washers) is it possible to attach/import it on a fabrication drawing instead of having it as a separate file?
example attached, importing / attach the " BOM A" onto a fabrication drawing.
Dias_Antonio
Dear @Anonymous
You can for example create a BOM in your drawing with a template, that is by default, stored inside this folder
C:\ProgramData\Autodesk\Advance Steel 2020\INT\Shared\Support\BOMTemplates
And after that generate your customized BOM. Seee this vieo on Youtube where you generate a BOM template in detail drawing
https://www.youtube.com/watch?v=dweAMupaPXY
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
thank you!
