When I zoom in any of my model object they disappear after a certain distance. Then when I zoom back out they reappear. I have purged and run an audit to fix errors but it still doing it. I have double-checked the hardware to make sure it meets the minimum hardware requirements and they in fact exceed the recommended ones.
I have made research on the internet about this issue but there is no solution posted for this issue.
Have their been a solution for this? happening for the first time with me now?
Dear @victor.garciaEST9Y
Despite you have said it is not a "Hardware issue", I suppose it is a Graphics Card problem or a Monitor problem. Try to run a test in other computer to check and confirm if this problems continues to happen
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
so after updating all the updates autocad and advance steel relate and multiple restarts nothing was hidden but couldn't select anything but hold down cages would show up in my properties. change a few settings which was weird but after i have done an custom hold down cage same thing happened can't select anything. tried on another computer working fine and once open on my computer mine no issues with that same corner.
Dear @DraftingSteelwork
I hope you have solved the problem...post your feedback of the complete solution when it is OK.
Antonio Dias
