Hi @Abhay_G_Shirodkar
If an IFC file from any software imports empty that file contains no intelligent data
If you open the file in an IFC viewer you will probably see the items, these are dumb 3D solids inside the IFC file called BREPs
Advance Steel cannot import these items as there is nothing intelligent to convert them to Advance Steel beams
There are 2 things you can do
1. Ask for an export with IFC elements not BREPs so there is some intelligence
2. Open the IFC file with AutoCAD architecture or Revit, these will see the BREPs as solid objects, you can then save or export as a DWG file which you can then open or XREF in Advance Steel and then model over the top of
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
