Import IFC from Strakon!!
Abhay_G_Shirodkar
Message 1 of 16
Abhay_G_Shirodkar
How do I import IFC file, which is been originated from DICAD software named Strakon? The Model is completely empty after the import of IFC file from Strakon.
Replies (15)
Message 2 of 16
Sebastian_Eiche
could you upload the ifc for having a  look?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 3 of 16
robertwmerriman1
Hi @Abhay_G_Shirodkar
If an IFC file from any software imports empty that file contains no intelligent data
If you open the file in an IFC viewer you will probably see the items, these are dumb 3D solids inside the IFC file called BREPs
Advance Steel cannot import these items as there is nothing intelligent to convert them to Advance Steel beams
There are 2 things you can do
1. Ask for an export with IFC elements not BREPs so there is some intelligence
2. Open the IFC file with AutoCAD architecture or Revit, these will see the BREPs as solid objects, you can then save or export as a DWG file which you can then open or XREF in Advance Steel and then model over the top of
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Message 4 of 16
Sebastian_Eiche
maybe additional, if the ifc content is full of BREP, you also use a free ifc viewer for Exporting for example STP files for importing this. There's no Revit or Architectural AutoCAD needed
Sebastian Eiche
Message 5 of 16
robertwmerriman1
Hi @Sebastian_Eiche
I not know that, thanks for sharing!
Message 6 of 16
Sebastian_Eiche
I used the fzk viewer in the past, if you Google for it you will find it.
Sebastian Eiche
Message 7 of 16
Abhay_G_Shirodkar
We are not able to open the file in Advance steel software.
I have shared you the IFC file of my project.. Please find the attachment.
Message 8 of 16
Sebastian_Eiche
There's no attachement...
and as @robertwmerriman1  wrote, the reason could be the content of the IFC becaus Advance is not able to import all IFC.
Sebastian Eiche
Message 9 of 16
Abhay_G_Shirodkar
The IFC file is not getting attach. But, the IFC file is opening and accessible in IFC viewer online(BIMspot).
Message 10 of 16
Sebastian_Eiche
you could create a zip file and upload this.
Sebastian Eiche
Message 11 of 16
Abhay_G_Shirodkar
Please find the Attachment.
Message 12 of 16
Sebastian_Eiche
I open it in the FZK Viewer and it looks ok to me, I found many ifc beams and so on but all these beams are looking like concrete beams, or walls and so on. This is the point, this elements could not be translate into AS Object, so AS will not import them
Maybe your viewer could export something like DWG or STEP? Or you go the way @robertwmerriman1 wrote with for example Revit
Sebastian Eiche
Message 13 of 16
Abhay_G_Shirodkar
Suggest me an IFC viewer, which can export DWG file.
Message 14 of 16
Sebastian_Eiche
I'm not sure if there's a way for exporting dwg, I know some viewer could export stp files. I go the way by using Revit and then exporting a dwg (I attache it but I don't know if it's correct). I sad: the IFC contains beams and so on, butSteel objects in themodel are saved as proxyelements
Sebastian Eiche
Message 15 of 16
markhubrich
I had the same issue in the past exporting IFC from SDS2 for use in Advance Steel. I had to export as EM11 IFC2x3 for AS to see anything at all.  I have no clue about your software but here's a shot from SDS2..
...and fix the kiss export issues.
Message 16 of 16
markhubrich
Attached is excel file of your IFC. Your file might not import if you are using US Imperial Advance Steel.
