just putting this out for comment...
Solved by steeldesgn. Go to Solution.
I used to get this a lot when there was an Orientation mark as part of the detail. Try turning that off -> update the detail -> turn back on if needed.
I have noticed during drawing production that if the scale of the view is to small to accept the position of the labels, I will get that huge green detail frame....
I then scale up the view to a bigger size, delete the labels, and then scale it back to the right size so I can manually replace the labels deleted.
I only describe my experience and work around.
