Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
huge green frame
3 REPLIES 3
muleman1
539 Views, 3 Replies
huge green frame
just putting this out for comment...
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
3 REPLIES 3
steeldesgn
in reply to: muleman1
Did you update your drawing? It looks like there is something in the upper left corner. Move it back inside drawing area and rectangle should return to normal.
I used to get this a lot when there was an Orientation mark as part of the detail.  Try turning that off -> update the detail -> turn back on if needed.
rbolinelfers
I have noticed during drawing production that if the scale of the view is to small to accept the position of the labels, I will get that huge green detail frame....
I then scale up the view to a bigger size, delete the labels, and then scale it back to the right size so I can manually replace the labels deleted.
I only describe my experience and work around.
