Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to remove "Reference" cutback/offset from beam length.
1 REPLY 1
693 Views, 1 Reply
I made a clip angle connecting two beams, but the top cope is not aligned with the intersecting beam once I added the clip angle. The cut back is 2 5/8" by default. The options to change to zero is grayed out. I tried to delete the grip point but when doing so it removed the bolts and everything. It will not allow me to move it either. I'm going to attach some images to better explain because I'm not sure if I am using the right terms.
Tags (1)
Labels (1)
1 REPLY 1
Jonathan.Jasinski
The "Cutback" shown in picture 2 is greyed out because those values are derived from the clip angle macro.  That also explains why, if you delete the shortening, the whole joint gets deleted.  Within the clip angle macro there is a value for "Cut Back" with reference to the face of the beam or the flange or the system line.  That value can be negative to extend the connecting beam into the supporting beam.  For your example, I would start with setting your reference to the "System Line" and changing the cutback value to -2 5/8".  Your manual cut that you have drawn previously would then be redundant.
Technology Administrators
